Оффлайн Quick
  • 538
Corona render for ArchiCad
« : Октября 26, 2018, 13:02:19 »
Total CHAOS 2018 KEYNOTE presents Corona Renderer (Alpha Version) for ARCHICAD (смотрим с 50:52)
It was on last month's CHAOSGROUP totalCHAOS event that an announcement was made by Renderlegion representative Mr Adam Hotovy that they are already working on a CORONA plug-in(add-on) for ARCHICAD. You may forward to 50:50 in the video on ChaosGroupTV youtube channel. It is called: Total Chaos 2018 — Opening keynote and below is the link. As you watch, take a look at what is happening on the video display wall in the back. You'll probably notice the CORONA guys wanted some feedback but I am more than sure that they didn't get it on this venue as totalCHAOS is for CG dev's and CG artists. So making CAD/BIM announcements on CG events is a good idea but stands zero to no chances to catch up. I think it would be massively great if the ARCHICAD Community and/or GRAPHISOFT provide some meaningful and useful feedback that could boost up this CORONA project.
VIDEO:
Источник https://archicad-talk.graphisoft.com/viewtopic.php?t=61404
Оффлайн BoogeyMan
  • 455
  • BIM & SIP
« Ответ #1 : Октября 26, 2018, 13:51:39 »
пробегала уже эта новость
Оффлайн DeMarko
  • 351
« Ответ #2 : Октября 26, 2018, 17:54:22 »
Ещё весной предвкушали, тогда они сами решали, хорошая это идея или плохая
Оффлайн Quick
  • 538
Оффлайн Quick
  • 538
« Ответ #4 : Ноября 16, 2018, 17:54:40 »
Corona Renderer for ARCHICAD is now in Alpha version that can be freely downloaded and used. It is not yet ready for production, we are waiting for your feedback, suggestions and bugreports to guide our development. We will publish any updates and new version of the plugin on this forum.
The plugin is available for ARCHICAD in versions 18* to 22, on 64-bit Windows only.
Please note that the support for ARCHICAD versions 18 and 19 is experimental, so you may encounter some issues or crashes. CoronaProxy and CoronaLight will not work with these versions. We will decide whether to support these outdated versions depending on your feedback.
This post will be kept up-to-date, you can always find the latest version here.
Оффлайн aspid
  • 241
« Ответ #5 : Ноября 17, 2018, 22:12:10 »
ООоо, уже новую тему запилили.... Уже поробовали, работает.
Оффлайн paradize
  • 140
« Ответ #6 : Ноября 20, 2018, 23:38:16 »
Если разработчики доведут функционал аддона до ума, это будет одно из самых серьезных улучшений ArchiCAD. Ну и первые личные впечатления
По сравнению с родным cinerender освещение экстерьера гораздо лучше.  Можно прогнозировать результат всей картинки еще в начале рендера , есть возможность остановить и продолжить рендер на след.день. Материалы однозначно ведут себя более адекватно (например арх.стекло).  Есть proxy объект под форматы obj и cgeo, но что-то obj не визуализирует. Попробую сделать со 2 форматом.  При настройке материала с текстурами 1) их не нежно подгружать в библиотеку 2) есть копипаст текстуры от одного свойства к другому (Graphisoft проснись наконец)
Интерьеры еще не пробовал.
Пока нет пресетов материалов т.е. не факт что при смене версии Архи или рендера ваши материалы сохранятся и вам не придется все это дело вручную (я в Максвеле через это прошел). Нет импорта  родных короновских материалов или расширенной библ. Координаты или угол зрения архикадовской камеры и короновской немного разнятся. Есть сдвиг. Не корректно работает Displacment  на стыках геометрии (стены 1 и 2 этажа) при бесшовных текстурах видны большие дефекты.  Сами материалы нужно сложнее  - n-ое количество слоев с масками и весом(степенью влияния). Прокси ребята, прокси. За это одно вам поставят памятник при жизни. Делать высоко полигональный антураж геометрией с пересчетом всей архикадовской БД это очень глупо и не менее затратно по ресурсам.
Оффлайн NeroR
  • 611
  • Ружицкий Нестор (архитектор) г.Киев
« Ответ #7 : Ноября 21, 2018, 20:52:03 »
Автор: paradize« : Ноября 20, 2018, 23:38:16 »
Если разработчики доведут функционал аддона до ума, это будет одно из самых серьезных улучшений ArchiCAD. ....... Интерьеры еще не пробовал.
"Попробовал" интерьер  .. рендеры по 10 минут, 1600*1200, Получается   конечно по короновски.
Что у меня не получилось  -
-Поворот текстуры , хотя карты  текстур были повернуты -может не там указывал в не том режиме  -
-Бамп на максимуме и нормализатор дисплейстмент текстурой  на морфе поделенном на полигоны результат минимальный.
-Свет от архикадовских люстр и ламп удалось увидать после отключения тени, падающая тень соответственно выключилась.Стандартные источники света  вроде как работают.
Солнце и окружение фон . Регулировка силы светимости -в окне короны , сама настройка углов  это в настроечном перспективном окне архикада.
Судя по наличию даты окончания триала в лицензии -посмотрим как она вырубит корону рендерер , мечты о том ,что доведут функционал и он станет чем то прилагаемым к ломаным Арчи бесплатно- ну посмотрим.
Но судя  по тому ,что выходя с архикада 22  начал баг репорт вылетать
... Это мне особенно не нравится .
Поэтому буду сносить - потестил - посмотрел - удалил...)))) всем удачи
Оффлайн aspid
  • 241
« Ответ #8 : Ноября 22, 2018, 06:36:35 »
Но это короновское освещение в разы лучше чем то что было до этого в Архикаде. Особенно хорошо  в Короне ЛайтМиксером выводить баланс естетсвенного и искуственного освещения. К сожалению нет врменеи поробовать. Может на выходных поиграюсь...
Оффлайн NeroR
  • 611
« Ответ #9 : Ноября 25, 2018, 01:40:24 »
А он тут работает?
Две картинки с   с одной сцены -  одна стена с правильной повернутой текстурой- вторая  без неё .. -- чудеса ...
Оффлайн aspid
  • 241
« Ответ #10 : Ноября 25, 2018, 08:41:22 »
Не знаю, вкладку видел. Надо было поиграться, времени не было. Может щас попробую...
Оффлайн aspid
  • 241
« Ответ #11 : Ноября 25, 2018, 12:04:44 »
не много поигравшись, как запустить Лайт Миксер так и не нашел. Скорее всего его еще не запустили. С ним очень удобно настраивать баланс естетсвенного и искуственного освещения. Добавил немного дисплейса на пол. Балан засветов тоже не корректно работает. ХДРАй карты хавает, но не особо заметны в освщении. Картинка однозначно лучше всего того что было до этого в АРхикаде, но не все функции короны еще реализованы. Что получилось, судите сам. P.S. Несколько раз вылетал ArchiCAD, на попытке редактирования короновских светильников.
  • 2879
« Ответ #12 : Ноября 25, 2018, 16:54:41 »
На пол  меда налили, наверное зря дисплайсмент добавили. Ладно завели вы меня, тоже поставлю, хоть на писюк, для мака нет еще короны в Архикад...((((
Оффлайн aspid
  • 241
« Ответ #13 : Ноября 25, 2018, 17:14:54 »
НА счет меда ,согласен. Глосси перекрутил, точнее на превьюхе нормально показывала, а на рендере стало понятно. Но дисплейс нормально отработал. Эта картинка минут 15-20 рендерилась, при этом шумы были сильноые 6-7% но хваленный денойзер на ГПУ отработал хорошо, быстро. в ОБЩЕМ ЛИЧНО МОЕ РЕЗЮМЕ ТАКОЕ. Хоть и не реализованы все плюшки Короны, а только кнопки пустышки, в любом случае лучше чем другие варианты. Для тех у кого вообще нет Макса или каких то сторонних инстументов, вообще находка. Если кому удалось запустить ЛайтМиксер, поделитесь как. У меня пока не получилось.
Оффлайн BOR
  • 955
« Ответ #14 : Ноября 25, 2018, 20:22:55 »
Почему ругается на Корону 3 при скачке, так как ехе файл?
FINAL RENDER STAGE 2: краткий обзор
Автор Владислав Кузмичёв (бывший sapiens) « 1 2  Все » Cinema 4D
