Оффлайн shishka09
  • 7
Проблема при закрытии AC
« : Января 08, 2022, 00:36:51 »
Памагити!
AC 23, 24 каждый раз крашится (пока без последствий) при закрытии программы.
Mac OS Monterey
Translated Report (Full Report Below)
Process:               ARCHICAD [3997]
Path:                  /Applications/GRAPHISOFT/*/ARCHICAD 23.app/Contents/MacOS/ARCHICAD
Identifier:            com.graphisoft.archicad23
Version:               23.0.0 v1 RUS (4006) (23.0.0.4006)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-01-08 00:23:40.0684 +0300
OS Version:            macOS 12.1 (21C52)
Report Version:        12
Bridge OS Version:     3.0 (14Y910)
Anonymous UUID:        6D73BC64-9453-DE12-13C9-B46B04225588
Sleep/Wake UUID:       0D8401D9-4A60-4A54-B982-64E0CD12FEF9
Time Awake Since Boot: 4200 seconds
Time Since Wake:       732 seconds
System Integrity Protection: enabled
Crashed Thread:        0  CrBrowserMain  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0xfffffffff8149873
Exception Codes:       0x0000000000000001, 0xfffffffff8149873
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [3997]
VM Region Info: 0xfffffffff8149873 is not in any region.  Bytes after previous region: 18446603336088410228
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      VM_ALLOCATE              7ffffffeb000-7ffffffec000 [    4K] r-x/r-x SM=ALI
      UNUSED SPACE AT END
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0   dyld                                    0x118adb501 start + 465
Thread 1:
0   libsystem_pthread.dylib              0x7ff80f08dfec start_wqthread + 0
Thread 2:: VolumeMounterThread
0   libsystem_kernel.dylib               0x7ff80f0583da __semwait_signal + 10
1   libsystem_c.dylib                    0x7ff80ef6d8a9 nanosleep + 196
2   Foundation                           0x7ff81004753d +[NSThread sleepForTimeInterval:] + 151
3   InputOutput                             0x11439d749 -[GSVolumeCacheBuilder asynchMountVolumes:] + 1080
4   Foundation                           0x7ff80ffb72c9 __NSThread__start__ + 1025
5   libsystem_pthread.dylib              0x7ff80f0924f4 _pthread_start + 125
6   libsystem_pthread.dylib              0x7ff80f08e00f thread_start + 15
И дальше еще куча буков!
« Ответ #1 : Января 08, 2022, 20:16:55 »
shishka09,  а всё потому, что эти версии несовместимы с OS Monterey.
Вот тут можно почитать:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
Апдейт для 24-й версии, который предусмотрен для решения проблемы совместимости, запланирован к выпуску только в феврале (Update 5 (70xx build).
При этом речи про 23-ю версию вообще не идет - она слишком устаревшая, несовместима и исправлять это не будут.
Оффлайн shishka09
  • 7
« Ответ #2 : Января 09, 2022, 15:20:00 »
Большое спасибо! С Монтереем много косяков вышло!
Оффлайн iPuh
  • 898
« Ответ #3 : Июля 17, 2023, 11:06:40 »
Товарищи,  кто может подкинуть мысль? в какой-то момент АС25 5010 RUS FULL  перестал закрываться полностью. То есть при выключении серый экран и верхнее меню висит но дальше ничего не происходит. Сначала на одном компьютере  с чистой виндой установил его и сразу то же самое. Но когда на другом рабочем компьютере спустя 4 месяца случилось это то это уже система. Обе ОС - WIN 10  на ноуте с WIN 11 пока за такой же период ничего не замечено похожего.
Оффлайн LXNN
  • 96
« Ответ #4 : Октября 06, 2023, 07:59:11 »
Такая же фигня. У меня появилась после установки архикадов 24 и 23, я подумал они что-то подпортили при установке. Та же версия архикада и та же система. А может винда обновилась и это её баг? Работал до этого в 25-ом больше года, не было проблем.
Оффлайн DeMarko
  • 397
« Ответ #5 : Ноября 27, 2023, 11:26:38 »
Думал, что только у меня такая проблема на ноуте с Win11 AC24, 25
Оффлайн kote
  • mghamGD
  • 783
  • овод
« Ответ #6 : Ноября 29, 2023, 13:23:17 »
Тоже самое выключаю только с диспетчера задач
Оффлайн iPuh
  • 898
« Ответ #7 : Апреля 26, 2024, 22:36:22 »
На WIN 11 25 версия продержалась больше всего - 1 год и 8 мес. И та же фигня. 26я тоже по дружбе аналогично не схлопывается самостоятельно.
