ArchiCAD 15 - Обновления
« : Сентября 21, 2011, 14:00:39 »
    ArchiCAD 15 - Обновления - Updates
    Обновления являются кумулятивными, т.е. достаточно установить только последнее обновление.
    « Последнее редактирование: Февраля 07, 2013, 21:53:21 от GAG »
    ArchiCAD 15 Hotfix-1 (Build 3267)
    « Ответ #1 : Сентября 21, 2011, 14:11:15 »
    List of bugs fixed in this Hotfix:
    • 128588    CRASH: In navigator, when clicking next to a rendered view that was already open for creating a new view, ArchiCAD crashed
    • 128290    CRASH: Selecting a Master Layout for trace reference caused crash
    • 96203    DOCUMENT: In USA version the 'Show Back References' parameter of the NCS Drawing Title element displayed gibberish
    • 112601    DOCUMENT: Under specific circumstances, zooming with PDF placed as drawing used up memory to the point where ArchiCAD crashed
    • 114201    DOCUMENT: Information dialog about borrowed license was appearing in the background instance of ArchiCAD and blocked the update process
    • 116488    DOCUMENT: Curtain wall, when placed and set to symbolic, did not show on floor plan if it was below the floor plan cut plane.
    • 118624    DOCUMENT:  In Index Settings imported from another file, the Layout and Layout Subset criteria were missing in the following case: in the original file, a drawing originating from an independent worksheet was relinked to another view
    • 122647    DOCUMENT: Plot files containing black and white image became larger than in ArchiCAD 14
    • 122752    DOCUMENT: Drawing Index Master layout column was empty under certain circumstances
    • 129130    DOCUMENT: In door schedule the 3d Front View was displayed with wrong orientation
    • 116244    EDIT: User Interface panel of Object Settings dialog disappeared after injecting parameters
    • 118361    EDIT: The position of a label assigned to a beam after placing it was different than if the beam was placed together with a label
    • 126081    EDIT: Create Guideline Segment tool was not selectable in 3D in the "Control Box" palette
    • 126089    EDIT: When selecting doors or windows one after the other, the “Sill or Header Height” parameter didn't update in the Infobox
    • 126140    EDIT: When copying a hole in a shell, there was no visual feedback on where the holes would be placed
    • 126974    EDIT: Ellipses drawn with the "up right" or "down left" method became segmented, and only their center hotspot could be selected
    • 127981    EDIT: Newly created element was displayed with "Show on current Renovation Filter only"
    • 128697    EDIT: Zooming in files with large black and white TIFF images became much slower
    • 128779    EDIT: While editing endpoint of a wall using SHIFT+R, the wall’s length is entered as the total length and not as an increment
    • 128840    EDIT: Setting the Base Height value before placing a Rectangular Mesh caused the upper plane to always stay on the 0.00 level
    • 128873    EDIT: In the Renovation Override Styles dialog: Setting Fill Background Color to 0 for “Elements to be Demolished” had no effect
    • 128924    EDIT: If dimensions had been placed onto a mesh with the gravity option, then editing the height of one side of the mesh didn't update the dimension values
    • 127116    FILE: 3D model was regenerated on save, if 'memory usage' setting in Work Environment was set to Low or Medium
    • 128954    FILE: ArchiCAD was crashing when opening particular autosave files
    • 128983    FILE: Saving a file which contains an ellipse with the bubble linetype generated an integrity error
    • 128507    FILE/DGN: Arcs in GDL elements were exported as whole circles in certain cases
    • 125867    FILE/GDL: When using the "Save 3D model as" feature and its default "Non-editable binary 3D data" option, the size of the GDL element became too large due to uncompressed textures
    • 111941    FILE/IFC: IFC file saved from particular ArchiCAD file made ArchiCAD crash when reopened
    • 116255    FILE/IFC: Space boundary export option was missing from the IFC Translation Setup (Export Options > Derived Model Data to Export)
    • 119266    FILE/IFC: The "Show selected tree element" button of IFC manager worked erroneously
    • 120819    FILE/IFC: IFC file containing invalid GUID's created an empty file without displaying a warning
    • 122405    FILE/IFC: When saving project to IFC, opening and then saving in Revit: setting the Project North to a value other than the default resulted in a rotated project in ArchiCAD
    • 123025    FILE/IFC: Particular file opened in ArchiCAD looked empty
    • 124528    FILE/IFC: Curve resolutions too low on curved edges/surfaces of objects created at IFC import.
    • 126981    FILE/IFC: Material parameter of objects created at IFC import was wrong
    • 127090    FILE/IFC: With particular ArchiCAD file, the export to IFC resulted in extra curved grid elements
    • 127095    FILE/IFC: In IFC file saved from particular ArchiCAD file grid lines, were missing
    • 127098    FILE/IFC: In exported IFC file, the geometry of the elements trimmed to Roof or Shell was wrong
    • 127256    FILE/IFC: Older IFC translators could not be used after importing them in ArchiCAD 15
    • 127309    FILE/IFC: Incorrect element ID's were created after importing particular IFC file
    • 127542    FILE/IFC:  Geometry of circular zones (ifcspace) was missing after IFC export
    • 127670    FILE/IFC: After merging particular IFC file into particular ArchiCAD file, some elements became displaced
    • 128470    FILE/IFC: If the Model Unit in the IFC translator was set to inch, then the model exported became 3.7 times larger
    • 128714    FILE/IFC: ArchiCAD was able to import IfcLine elements
    • 129097    FILE/IFC: ArchiCAD did not create zone relations and space boundaries on specific file
    • 129292    FILE/IFC: After opening IFC file, several Find and Select criteria were missing
    • 118593, 123870, 124509, 127512    FILE/CRASH-FREEZE: ArchiCAD crashes when opening particular files with embedded libraries
    • 120219    FILE/MIGRATE: If files of older versions were consolidated at opening, placed library elements could became missing
    • 118529    GDL: GDL didn't support STW function in Doors/Windows
    • 119508    INSTALL: Hotfix silent installer didn't update ArchiCAD if BIMServer and BIMServer Manager had already been installed on the same computer, or if another ArchiCAD of the same version had been installed
    • 125557    MODEL: After copy-pasting Roof accessories created in ArchiCAD 14 into ArchiCAD 15, accessories changed their height upon opening a section
    • 128409    MODEL: Skylights placed in a shell became erroneously displaced after dragging, mirroring or rotating them
    • 126660    MODEL: Trimming two roofs with particular geometry together generated error "wrong hole definition"
    • 122480    MODEL: With large radius the circular Stairmaker stair became very segmented
    • 118531    TEAMWORK: Even if both the project containing the layouts and the project containing the source views were open in separate instances of ArchiCAD, an extra ArchiCAD instance was started for drawing update
    • 126163    TEAMWORK: User couldn't see the texts entered by another user into Index schedules
    • 126707, 126728    TEAMWORK: In certain circumstances some users could go offline while others still were online
    • 126976    TEAMWORK: Particular plan file couldn't be shared as a Teamwork project
    • 126990, 126992, 127147     TEAMWORK: Uploading of libraries could be slow in cases of large projects
    • 127147    TEAMWORK: In certain circumstances requests were not received by team members
    • 127186    TEAMWORK: Annotations on Interactive Schedules could get lost in Teamwork
    • 128439    TEAMWORK: In certain situations the BIM Server created backups that could not be used later
    • 128553    TEAMWORK: With certain projects the first download from BIM Server took much more time than data transfer time
    • 128724    TEAMWORK: Network traffic was sometimes large due to management data
    • 128147    TEAMWORK/CRASH: BIM Server was often crashing with particular hardware
    • 128537    TEAMWORK/DATA LOSS: In a second instance of ArchiCAD, floor plan data could get lost on the server after dragging elements over the Info Box and Tracker and then closing the appearing dialog
    • 124387    USER INTERFACE: On Mac OS 10.7 (Lion) Dialog windows could not be stretched if grabbed at their edges
    • 128316    USER INTERFACE: On Mac OS 10.7 (Lion) Palette could not be dragged if grabbed at the Title Resize area
    Bugs fixed in optional Graphisoft Add-Ons:
    • 126525    BIMx: If BIMx executable for Windows was saved from Mac, then the resulting file displayed wrong layer names on Windows if the layer names contained national characters
    • 127719    EcoDesigner: "EcoDesigner report header text" parameter was missing from Project Info after installing EcoDesigner in some language versions of ArchiCAD
    • 125296    EcoDesigner: After changing Mark Up Highlight in EcoDesigner, the Model Review Palette still showed the old colour
    • 127181    EcoDesigner: Ratio of openings in walls were calculated incorrectly
    • 127050    Google Earth Connection: On Windows OS, upload of model to 3DWarehouse was not possible
    • 117990    MEP: While using routing in the Tracker, one couldn't add or subtract a value from the orginal length (as is possible with the line tool)
    • 127664    ODBC driver: On Windows, ODBC configuration wizard didn't work properly
    Скачать:
    Windows 32-bit (all languages)
    Windows 64-bit (all languages)
    Mac (all languages)
    « Последнее редактирование: Февраля 07, 2013, 21:48:58 от GAG »
    • 958
    ArchiCAD 15 Hotfix-2 (Build 3602)
    « Ответ #2 : Февраля 07, 2013, 21:50:03 »
    Исправлено:
    • 132425   API: Could not save IFC file by using the API
    • 125886   API: Element lists provided for Add-Ons were not filtered based on Renovation Filter
    • 133879   CRASH: ArchiCAD 15 BIM Server Manager could crash while in User Settings
    • 129936   CRASH: ArchiCAD could crash after rebuilding section/elevation or regenerating drawing containing a shell
    • 129682   CRASH: Recovering project crashed ArchiCAD if particular Work Environment profile had been imported
    • 125855   CRASH: ArchiCAD could crash on editing "User Environment"
    • 123018   CRASH: In particular circumstances ArchiCAD could crash after double-clicking
      on an elevation in the view map while the layout window was active
    • 119292   CRASH: In certain situations undoing a Solid Element Operation between a wall and library element could crash ArchiCAD
    • 114689   CRASH: ArchiCAD could crash with particular projects after switching between two instances of the application
    • 129753   DATA LOSS: ArchiCAD displayed  library elements as missing in projects with
      placed library elements without a GUID and containing "/" character in
      their names
    • 133379   DOCUMENT: In PolyRoof Interactive Schedule the value of the "Holes Perimeter" was calculated erroneously
    • 131138   DOCUMENT: A Layout ID renamed in the Navigator reverted to its original value and
       could not be received by other users in a Teamwork project
    • 130839   DOCUMENT: With particular file in the Sheet Index List several Layout were associated with the wrong Master Layout
    • 130768   DOCUMENT:  Some dimensions and/or dimension points referring to composite
      structures were missing when opened in an ArchiCAD 15 Teamwork project,
      or an Autosave file
    • 130000   DOCUMENT: Publishing failed if the file contained at least one External Drawing and its source file was still open
    • 129951   DOCUMENT: After placing a new window and creating a view with the renovation
      filter set to '03 After Demolition' the window did not show
    • 129925   DOCUMENT: In the Interactive Schedule  a rounded/circular polyline placed as annotation appeared erroneously
    • 129479   DOCUMENT: In the Interactive Schedules numeric elements were sorted in dictionary
       order instead of numerically. For example: 1, 10, 11, 2
    • 129156   DOCUMENT: Sill/Header values were summed up when listing multiple Doors/Windows
    • 127992   DOCUMENT: Window/Door nominal sill height couldn't be set in the Interactive Schedule
    • 127557   DOCUMENT: In Interactive Schedules Cyrillic fonts were shown as question marks on Layout
    • 127366   DOCUMENT: Using Offset Edge pet palette command on polygon of a dwg drawing placed as External Drawing crashed ArchiCAD
    • 126926   DOCUMENT: X-Y only geometry method Dimensions didn't work if Grid Rotation
      Anglewasn't the default (even when rotated grid is turned off)
    • 114251   DOCUMENT: In case of slabs with composite cut fill structure of skins didn't get
      displayed by slab label after changing from text label to slab label
    • 132136   DOCUMENT/DATA LOSS: A dimension chain lost segments when Curtain Wall ID had been changed
    • 127178   DOCUMENT/DATA LOSS: Some dimensions were lost after trying to subtract a polygon from a Fill, Slab, or Roof
    • 115987   DOCUMENT/DATA LOSS: Saving file, moving Curtain wall, dragging a copy of Curtain wall
       along with its dimension could alter the dimension string associated
      with the Curtain Wall reference line
    • 131681   EDIT: In Windows-Doors Settings, after changing Reveal Depth, Sill/Threshold depth was also set to the same value
    • 131565   EDIT: Hotspots of doors/windows could be misplaced after resizing the containing wall
    • 131257   EDIT: Choose Hotlink dialog was opened slowly if there were non-valid hotlink file locations
    • 129500   EDIT: The caret that indicates the position of typing changed constantly in
      OS X Lion when a text box was created by double click
    • 129295   EDIT: Element ID Manager changed ID's of doors in reverse order
    • 129216   EDIT: In the Text Box the text didn't get wrapped in certain situations
    • 127498   EDIT: Window lost its  renovation parameter after splitting containing wall
    • 126962   EDIT: With a particular project W1 Trapezoid 14 window could jump into another plane when clicking on its hotspot
    • 126765   EDIT: When elevating a ridge of a multi-plane roof in section the height of the roof wasn't set accordingly
    • 133409   FILE/C4D: Alpha channel was not saved with C4D files
    • 119314   FILE/DGN: Saving to DGN succeeded only after the second trial
    • 130873   FILE/DWF: If Rotated Views are exported to DWF, its elements will be exported with modified coordinates
    • 110172   FILE/DWF: After exporting layout to DWF the model space coordinates of the elements could not be measured
    • 132479   FILE/DWG-DXF: Rotated 2d polylines were imported incorrectly
    • 129379   FILE/DWG-DXF: Shells' Floor Plan view wasn't exported to DWG
    • 116531   FILE/DWG-DXF: Layers of the DWG-DXF template file were exported to DWG even though
      the "Do not export empty layers" checkbox was checked
    • 103405   FILE/DWG-DXF: Drawing with rotated orientation was exported to DWG-DXF with rotated coordinates in model space
    • 130443   FILE/DWG-DXF/CRASH: Data in DWG data not compatible with their nominal file format could crash ArchiCAD at import
    • 133813   FILE/IFC:  IFC based quantity for roofs and shells were missing in exported IFC file
    • 133758   FILE/IFC:  Contour lines of windows and doors were missing after importing an IFC file saved by ArchiCAD
    • 133704   FILE/IFC:  Walls lost their IFC properties if its Element Classification was set to "Wall"
    • 133561   FILE/IFC:  Some openings didn't create holes in walls with complex profiles in exported IFC files
    • 133533   FILE/IFC:  When ArchiCAD 14 file was opened by ArchiCAD 15, the ID of elements was overwritten by the ID's set in the IFC Data
    • 133292   FILE/IFC:  In IFC Manager one couldn't drag and drop a group of elements into another folder
    • 132747   FILE/IFC: Columns could be misplaced at IFC import
    • 132715   FILE/IFC: Height of walls could be miscalculated by ArchiCAD when opening Tekla models
    • 132274   FILE/IFC:  In IFC files saved by ArchiCAD and opened in Revit applications openings were offset
    • 132225   FILE/IFC:  IFC Properties could not be defined in the Objects' Settings Dialog, after the use of the "New and Reset All" command
    • 131989   FILE/IFC:  After saving an IFC file from certain projects the "Type" of the wall
      contained only the thickness of the wall instead of the name of the
      composite fill
    • 131829   FILE/IFC:  Some elements could be rotated after importing particular IFC files to ArchiCAD
    • 131662   FILE/IFC:  In IFC files exported by ArchiCAD, doors didn't have opening lines
    • 131576   FILE/IFC:  Some openings didn't create holes in walls in exported IFC files
    • 131449   FILE/IFC:  After importing a particular IFC file into ArchiCAD some doors were placed in front of the walls they belonged to
    • 131058   FILE/IFC: Automatic export of Zone Categories was missing from IFC export. For
      the fix to work you will need to set a Registry Key  in AC 15. See Wiki article.
    • 130844   FILE/IFC:  Imported IFC file elements could change size if their settings window
      was viewed and the "OK" button was used to leave the dialog
    • 130713   FILE/IFC: Zones could be missing in the exported IFC file if Partial Structure
      Display has been set to "Core of load-bearing elements only"
    • 130194   FILE/IFC: If the geometry of the axis of an  IFCGrid was IFCLine ArchiCAD could not import it
    • 130027   FILE/IFC: In IFC file exported by ArchiCAD and imported into Revit the frames of particular Curtain walls were rotated
    • 129577   FILE/IFC: Walls were exported as simple IfcWall elements instead of IfcWallStandrardCase
    • 128579   FILE/IFC: certain walls from AutoCAD Architecture/MEP weren't displayed in ArchiCAD
    • 128231   FILE/IFC: Profiles of particular beams could be rotated by 90 degrees after importing IFC file
    • 126846   FILE/IFC: Properties of Door/Window Type were missing from IFC export
    • 113961   FILE/IFC: Walls could be misplaced at IFC import with particular IFC file
    • 131169   MODEL: On Section/Elevation Multiplane Roof set to Existing renovation status
      lost its contours if Renovation Filter was set to "Planned"
    • 130221   MODEL:  in 3D Window object and casing could be erroneously positioned in Profiled Wall
    • 126461   MODEL: Window Size couldn't be overwritten by parameter script
    • 127552   MODEL/DATA LOSS: Window lost its renovation parameter and reverted back to
      "existing" after using Drag a Copy on the containing wall
    • 129181   TEAMWORK: ArchiCAD could crash after migrating particular project
    • 128969   TEAMWORK: BIM Server's backup scheduler wasn't working according to the Project  Backup Schedule
    • 128609   TEAMWORK: Importing a particular project file could crash the BIM Server Manager
    • 130175   TEAMWORK: In BIM Server Manager managing users and projects was very slow
    • 110642   TEAMWORK: Project Settings could freeze in case of connection through internet
    • 133576   TEAMWORK: Server Activities window of Activity Monitor could display wrong
      Project Names after deleting the "Everyone" entry from the list of users
       of the project
    • 118544   TEAMWORK: Unsent changes prevented layout update
    • 120735   TEAMWORK: Updating Server Activities data in BIM Server Manager was slow
    • 110453   TEAMWORK: User Settings window could freeze in case of connection through internet
    • 131009   TEAMWORK: Optimizes the processing of layers during a hotlink update, thereby improving performance
    • 120732   TEAMWORK/CRASH: Changing the preferred timeframe  in the Server Activities window of  BIM Server Manager caused its crash
    • 128273   TEAMWORK/CRASH: In certain situations ArchiCAD could crash when trying to join a migrated project
    • 127572   TEAMWORK/CRASH/FREEZE: Changing Backup Schedule for a project and pressing OK could crash or freeze ArchiCAD
    • 131834   TEAMWORK/DOCUMENT: If Update command was given from the Documents/Drawings/ menu then non
      reserved drawings were also updated, but since changes in non reserved
      drawings are not sent to the server local user sees different state of
      the drawings in comparison to other Teamwork users
    • 129977   TEAMWORK/MODEL: Different clients could see different colors for the same materials of complex profiles
    Bugs fixed in optional Graphisoft components
    • 130644   BIMx: After saving particular large projects to BIMx, they showed empty in BIMx
    • 133374   BIMx: ArchiCAD was freezing at exporting textures with particular project
    • 129541   BIMx: BIM Explorer or BIMx Desktop Viewer gave File error when opening a
      .bimx file by double-clicking on it or by dragging it on the application
       due to the name containing special characters
    • 132404   BIMx: BIMx did not work on some computers with integrated Intel graphics
    • 132153   BIMx: BIMx export didn't succeed if User Name contained characters with ASCII code above 127
    • 131953   BIMx: Export of BIMx file failed if the the OS userhome parameter had been set to the root of the file system
    • 130734   BIMx: Particular project could not be saved to BIMx do to a file dialog problem
    • 130055   BIMx: Particular project if  exported BIMx some textures were missing
    • 132483   BIMx: Quad Buffered Stereo mode could not be used in BIMx
    • 132480   BIMx: Textures were not shown on picture object
    • 129378   ECODESIGNER: With particular project Net Heating Demand could be calculated
      erroneously when setting Heat pump for fresh air heating
    Download this Hotfix
    • 958
    ArchiCAD 15 Hotfix-3 (Build 3632)
    « Ответ #3 : Февраля 07, 2013, 21:50:34 »
    • 133590 DOCUMENT/DATA LOSS: Dimensions could be deleted when opening file due to loading attributes in wrong order
    • 137590  DOCUMENT/DATA LOSS: Dimensions on object could get lost when changing views with different Renovation filters
    • 138584  DOCUMENT/DATA LOSS: In section, Dimension points were allowed to be added to a Grid tool Dimension chain. These added
      dimension points would be lost once the user navigated away from the
      section
    • 141507 DOCUMENT/DATA LOSS: Dimension node point of objects could get lost when switched to a view where the object became invisible
      according to the associated Renovation Filter
    • 133590 FILE/MODEL: One needed to open project twice so that correct complex profiles were loaded
    List of bugs of the installer executable fixed in this Hotfix:
    • 137596 INSTALL: In addition to the “silent” parameter a new “nowarning” parameter will prevent any dialog from showing on user
      screens concerning already patched components
    • 138263 INSTALL: On computers with multiple language versions of ArchiCAD it is now possible to silently update specified language
      versions with the “searchlanguage=xxx” parameter.   “xxx” is the three
      letter code for the localization, for example: INT, GER, FIN
    • 141813 INSTALL: Patches the uninstaller to be compatible with Java 1.7.
    • 958
    ArchiCAD 15 Hotfix 4 (Build 3898)
    « Ответ #4 : Февраля 07, 2013, 21:50:58 »
    • 136391  DOCUMENT/DATA LOSS: Additional parameters of Door markers could disappear from the Interactive Schedule
    • 128363  DOCUMENT: Drawing of elevation became rotated when placed on layout
    • 137014  DOCUMENT: Label associated with skylight didn't appear on layout
    • 117328  DOCUMENT: Pen set changed after copying a drawing on Layout
    • 138087  DOCUMENT: Update Zone command could give wrong results with Zones trimmed to Roofs
    • 131267  EDIT: Choose Hotlink Dialog also displayed modules that were not placed in the project
    • 133601  EDIT: Click to Trim function was executed very slowly if there were many fills in the project
    • 133709  EDIT: Column labels disappeared in view, but still appeared in Layout
    • 123052  EDIT: Curtain Wall could not be edited in particular project
    • 131942  EDIT: Fill in the hotlinked file was changed after placing the hotlink in the host file
    • 127470  EDIT: Pet Palette of Multi-plane Roof or Shell disappears both in 2D and 3D right after clicking on any of their
      hotspots or outlines.
    • 134333  EDIT: Wall recesses to Zone are not selectable
    • 131180  EDIT/CRASH: ArchiCAD could crash when on a Detail view a closed polyline was edited
    • 134841  FILE/DWG-DXF/IMPORT: Particular dwg file could not be imported
    • 136757  FILE/DWG-DXF/CRASH/: ArchiCAD could crash after deleting all DWG Translators and creating a new one
    • 138178  FILE/DWG-DXF/EXPORT: Duplicate dimension text was left behind in AutoCAD, after moving or deleting a dimension imported from
      ArchiCAD dimension chain
    • 131118  FILE/DWG-DXF: Parts of the DXF-DWG Translator dialog could not be accessed on lower screen resolution
    • 133251  FILE/EXPORT: Long schedule couldn't be saved to XLS (Excel) format
    • 134290  FILE/EXPORT: Skylight Labels were not exported to PDF
    • 135611  FILE/IFC/EXPORT: ArchiCAD exported the curved parts of the complex profiles as polylines instead of real curves
    • 136106  FILE/IFC/EXPORT: Base quantity of elements on which Solid Element Operation were applied were exported to IFC with incorrect
       Base Quantity
    • 136356  FILE/IFC/EXPORT: Elements clipped by Roof could lose the clipping information when exporting particular file to IFC
    • 136878  FILE/IFC/EXPORT: From particular ArchiCAD file slabs were exported with erroneous geometry
    • 136339  FILE/IFC/EXPORT: Mirrored copies of Columns rotated around their vertical axis lost their mirrored status when exported to
      IFC
    • 137420  FILE/IFC/EXPORT: With particular project elements were missing from the exported IFC file
    • 135451  FILE/IFC/IMPORT:  Particular IFC file was imported with erroneous geometry of trimmed cylindrical beams
    • 139834  FILE/IFC/IMPORT: IFC didn't import site geometry in a special case
    • 139753  FILE/IFC/IMPORT: IFC object based hotlinks lost their materials
    • 135898  FILE/IFC/IMPORT: Materials of elements went wrong when importing a particular IFC file
    • 139835  FILE/IFC/IMPORT: Negative length value erroneously generated by Tekla was not handled by ArchiCAD's IFC import
    • 136394  FILE/IFC/IMPORT: Opening particular file resulted in wrong 3D model of some elements due to invalid Brep preparation of
      elements
    • 131450  FILE/IFC/IMPORT: When opening particular IFC file some pipe elements could go wrong
    • 138127  FILE/IFC/IMPORT: Columns had incorrect rotation angle in a particular IFC file
    • 136520 MODEL: When an object went into an invisible renovation status it could change its position on the floor plan
    • 138051-138058  MODEL/DATA LOSS: Data of Roof elements could go Invalid
    • 137645  MODEL/FREEZE: With specific file ArchiCAD could hang after selecting area with a marquee and viewing it in 3D
    • 136294  TEAMWORK: During Send and Receive A “serious error has occurred" error message could come up in specific circumstances
    • 139480  TEAMWORK: IFC groups in mod file could cause "Server returns error code" error
    • 139547  TEAMWORK: In Teamwork project ownership violation error could occur after deleting an operator in a SEO operation coming from a
      hotlink module
    • 139576  TEAMWORK: Project could get into a state when a view with "Free for reservation" status could not be reserved
    • 140019  TEAMWORK: Reduce frequency of database commit failures by improving XREF handling algorithms
    • 129195  TEAMWORK: Several users of particular project could not read local cache, and could not join the project due to invalid elements
    • 137597  TEAMWORK/CRASH: After placing particular Teamwork project with custom profiles in it into another Teamwork file as a
      hotlink caused crash
    • 138855  TEAMWORK/CRASH: ArchiCAD could crash when joining a Teamwork project if third party add-ons were used with the project
    • 137148  TEAMWORK/CRASH: ArchiCAD could crash when sharing a Teamwork project if third party add-ons were used with the project
    • 139092  TEAMWORK/CRASH: Crash could occur after granting embedded library elements
    • 126758  TEAMWORK/CRASH: When  opening particular project "Internal error found, ArchiCAD will be closed" error message came up,
      after pressing OK ArchiCAD crashed137842  TEAMWORK/LIBRARY: "Library
      update failed" error could come after adding specific shared library to a
       project
    Bugs fixed in optional Graphisoft components:
    • 129783  BIMx: "Play On Start" function didn't work
    • 138083  BIMx: BIMx viewer crashes when trying to save file on Vista
    • 136407  Cinema4D: Could not update the C4D plan without overwriting the materials of modified elements and duplicating them
    • 134985  Cinema4D: C4D file with materials that had PNG textures and alpha channel went wrong after reopening them in ArchiCAD
    • 958
    ArchiCAD 15 Hotfix 5 (Build 4056)
    « Ответ #5 : Февраля 07, 2013, 21:51:44 »
    Исправлено:
    • 148558   CRASH: ArchiCAD could crash on startup if DisplayOptionPreferences.xml contained incorrect parameter.
    • 127423   CRASH: ArchiCAD could crash when changing the output format of a publisher set.
    • 138142   CRASH: Crash could occur when opening certain plans that contain IFC Groups coming via hotlinks.
    • 113909   CRASH: Third party Add-ons could make ArchiCAD crash
    • 131644   CRASH: With particular projects ArchiCAD could crash on saving or publishing PDF'S http://archicadwiki.com/Bugs/PdfExportCrashOnMac
    • 143903   DATA LOSS: Data of Roof elements could go Invalid with particular file
    • 145594   DOCUMENT: Elements were visible on Interior Elevation outside of its horizontal range.
    • 146691   DOCUMENT: In schedules the door and window sill/header values are always listed
      relative to wall base, and not the selected anchor point.
    • 148122   DOCUMENT: In schedules the door and window sill/header values are always listed
    • 147597   DOCUMENT: Incorrect display of dotted lines if 2D antialiasing is turned off.
    • 145593   DOCUMENT: Interior Elevation Marker rotates when limit line is extended
    • 146463   DOCUMENT: Listing doors by opening direction in the Element ID Manager listed the same doors separately.
    • 146209   DOCUMENT: Under special circumstances Grid System can be lost from project after manipulating Section settings
    • 139821   EDIT: At junctions of adjacent polygonal walls unneccessary cut line appeared
       despite "PolyWall Corners Can Change" checkbox being checked in.
    • 131542   EDIT: Choosing Select Object by Favorite Objects in the Additional Parameters
       chooser of the Element Schedule Scheme could make ArchiCAD crash.
    • 134179   EDIT: Cut fill and cover fill was not available from the object and stair setting window
    • 144255   EDIT: Layer visibility could change after zooming or panning
    • 144794   EDIT: On MAC OS X 10.8 dotted lines were not visible http://archicadwiki.com/OsxMountainLion#Known_issues
    • 143094   EDIT: On MAC OS X some icons were wrong when HiDPI display was used
    • 143091   EDIT: On MAC OS X some popup windows could come up in wrong position when HiDPI display was used
    • 107293   EDIT: On windows 7 tooltips on pallettes were missing if DPI of the OS was set above 100%
    • 127508   EDIT: Polyline could not be exploded into individual segments
    • 127184   EDIT: Structural function, Position and Element Classification were not stored in Favorites
    • 148207   EDIT: Zone data could grow causing performance problems.
    • 141345   FILE/DWG/EXPORT: In DWG file expored with the "Paper space with full view's content" the model content could be offset
    • 137612   FILE/EXPORT: In particular circumstances 3DS export function of ArhiCAD could create
       files that were not readable by 3D Studio MAX.
    • 142574   FILE/IFC/EXPORT: Exporting IFC file from project containing Walls of complex profile with Wall End element made ArchiCAD crash
    • 134247   FILE/IFC/EXPORT: With particular project IFC-Columns could be placed in incorrect position during IFC export
    • 144496   FILE/IFC/EXPORT: With particular project the exported value for IfcBuildingLocalplacement was wrong
    • 133396   FILE/IFC/IMPORT: As a new feature, ArchiCAD converts as much IfcDistributionElements as
      possible to native ArchiCAD MEP elements.
    • 143024   FILE/IFC/IMPORT: Curtain Wall and its sub-elements were imported with the wrong hierarchy in the IFC tree
    • 145507   FILE/IFC/IMPORT: Hotlinked IFC elements with custom profiles could be misplaced in the host file.
    • 144170   FILE/IFC/IMPORT: IfcEnergyConversionDevice-type IFC model elements were missing after IFC import.
    • 143028   FILE/IFC/IMPORT: Importing particular file created objects with missing geometry
    • 140095   FILE/IFC/IMPORT: Importing particular IFC file into ArchiCAD could cause beams being placed or cut erroneously
    • 140800   FILE/IFC/IMPORT: Manual story-matching at Detect IFC Model Changes gave different
      position between the compared two model versions.
    • 142962   FILE/IFC/IMPORT: Particular elements originating from Tekla Stuctures could be misplaced during import
    • 140798   FILE/IFC/IMPORT: Walls being extruded from top to bottom were misplaced at IFC import
    • 143027   FILE/IFC/IMPORT: When importing particular IFC file a lot of elements went missing
    • 145507    FILE/IFC/IMPORT: Hotlinked IFC elements with custom profiles could be misplaced in the host file because of attribute name
      collision. We have created a registry option to embed these profiles in
      the elements as special Custom profile instead of editable profile
      attribute. For this registry (PC) or Preferences (Mac) option to be set
      please do take the following steps:
    • Start ArchiCAD. Go to the File / File Special / IFC 2x3 / IFC Translation Setup menu item. Press the Save Settings and Close button. As a result in the registry (PC) or Preferences (Mac) a folder called IFC will be created under the main folder of the ArchiCAD 15 or 16 version.
    • One has to go to the the Registry Editor on Windows or open the Preferences on MAC as advised here:http://www.archicadwiki.com/RegistryOrPreferences.
    • Users have to create a key called ImportUnnamedProfilesAsCustom under the IFC folder.
    • On Windows the key should be a DWORD type and its value has to be set to 1, on Mac it should be a Boolean type and its value has to be TRUE.
    • Save the Preferences file on Mac, close the Registry Editor on Windows.
              Note: Users can later capture and duplicate these custom
      profiles using the "Capture element's profile..." option in the Profile
      Manager.
            [/size]
    • 127606   FILE/SAVE: Saving back to previous ArchiCAD version with a name containing
      accentuated letters could cause that embedded objects became missing.
    • 134076   MODEL: Beams without connecting reference lines did not cut each-other affecting also listed quantities
    • 126767   MODEL: 3D window didn't show the backround image with Internal Engine
    • 142260   MODEL: Calculation of 3D zones bordered by multystory walls could be different
       depending on the story where the Update Zones command was used
    • 143764   MODEL: Hotlink Module could move to a different story after breaking a copy of the original one and resaving it.
    • 143130   MODEL: In particular circumstances in the Navigator Project Map some floors
      show up multiple times, or with wrong floor number (while in the Story
      Settings dialog everything is OK)
    • 144267   MODEL: Particular Composite structure got invalid skins after appending it through attribute manager
    • 130684   PUBLISH: When printing from floor plan (instead of layout) the fills were
      printed as if their Construction Method would have been changed from
      "Relative to Fill Origin" to "Relative to Project Origin"
    • 130348   PUBLISH: With particular projects Interior Elevation names in Project Map could stop reading the zone data
    • 132643   SPEED: ArchiCAD could become unresponsive after 3D navigation with projects containing particular GDL objects
    • 143629   SPEED: Generating elevation was slow if walls had many hotspots.
    • 128993   SPEED: With projects containing large Curtain Walls after selecting elements
      by the Rectangle geometry method hotspots appeared after a long time
    • 142197   TEAMWORK/DATALOSS: Custom text could disappear from Project Index sheet after closing the plan and joining again
    • 146072   TEAMWORK/DOCUMENT: Dimension texts were missing until zooming in from independent sections after sharing the project.
    • 147902   TEAMWORK/EDIT: Warning message will appear when editing a slab without reserving the
      level dimensions that were placed with gravity onto that slab. http://www.archicadwiki.com/Teamwork/Troubleshooting/LevelDimensionsMove
    • 144203   TEAMWORK/LIBRARY: If a library had been uploaded to a BIM Server from a mapped network
      drive in a previous version of ArchiCAD then it could not be refreshed
      in the current one.
    • 142394   TEAMWORK: Custom model view options under certain circumstances incorrectly handled reservation information.
    • 143521   TEAMWORK: Files where IFC groups in mod file caused "Server returns error code" error were not corrected on open.
    • 142399   TEAMWORK: Restore from Autosave file could not be possible in particular circumstances
    • 140868   TEAMWORK: With particular workflow creation, reservation, and request/grant
      functions used on layers could cause "Server returns error" warning
    • 141235   BIMx: Shading of double curved ruled surfaces was wrong
    Скачать
