Djorjik
помогите разобратся с ноутбуком, или в мусор
System Information
Time of this report: 7/17/2008, 03:54:58
       Machine name: DJORJIK
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.051011-1528)
           Language: Russian (Regional Setting: Russian)
System Manufacturer: Hewlett-Packard
       System Model: HP Compaq nx9420 (RH442ET#ABD)
               BIOS: KBC Version 54.3B
          Processor: Intel(R) Core(TM)2 CPU         T5600  @ 1.83GHz (2 CPUs)
             Memory: 1024MB RAM
          Page File: 187MB used, 2273MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 10.0 (4.10.0000.5512)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: The file system.dll is missing! You should reinstall DirectX to get the latest version.
      Display Tab 1: The system is using the generic video driver.  Please install video driver provided by the hardware manufacturer. Direct3D functionality not available.  You should verify that the driver is a final version from the hardware manufacturer.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name:
     Manufacturer:
        Chip type:
         DAC type:
       Device Key: Enum\
   Display Memory: n/a
     Current Mode: 800 x 600 (32 bit) (1Hz)
          Monitor:
  Monitor Max Res:
      Driver Name: vga.dll
   Driver Version: 5.01.2600.0000 (Russian)
      DDI Version: unknown
Driver Attributes: Final Retail
 Driver Date/Size: 8/18/2004 14:00:00, 9344 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD:          Mini VDD: vga.sys
    Mini VDD Date: 8/18/2004 14:00:00, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
        Vendor ID: 0x0000
        Device ID: 0x0000
        SubSys ID: 0x00000000
      Revision ID: 0x0000
      Revision ID: 0x0000
      Video Accel:
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Not Available
       D3D Status: Not Available
       AGP Status: Not Available
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Re: Ноутбук HP: DirectX Files Tab, The file system.dll is missing!
« Ответ #1 : Июля 17, 2008, 16:52:09 »
Судя по всему норм, только не понятно что за видео?
« Ответ #2 : Июля 17, 2008, 16:59:58 »
там написано, что надо (почему-то)реинсталлить DirectX до последней версии
вроде так...
Djorjik
« Ответ #3 : Июля 17, 2008, 17:58:05 »
Вот что есть, а не подскажите какие игры можно ставить? я еще новичок в этом. проинсталировал игрушку и дает eror direct 3D. спасиб
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
« Ответ #4 : Июля 17, 2008, 19:31:15 »
System Information
DxDiag Notes
Direct3D:    0/4 (n/a)
Display Devices
          Monitor:
  Monitor Max Res:
Вот вроде оставил из твоего сообщения все , на мой взгляд проблемное.
С ходу директХ 10 под ХР  не его тема, плюс разрешение 800х600 - прошлый век. И т.д.
« Ответ #5 : Июля 17, 2008, 20:41:52 »
Лучше ссылку на страницу производителя дай, а то нифига ведь непонятно.
Оффлайн kudrjash
  • 140
« Ответ #6 : Июля 18, 2008, 00:18:56 »
Наверно этот  :google:
А вообще он уже снят с производства и тех. информацию по нему не найти
« Ответ #7 : Июля 18, 2008, 00:21:17 »
По моему вполне себе крутой ноут.
Оффлайн kudrjash
  • 140
« Ответ #8 : Июля 18, 2008, 00:24:37 »
Видео маловато. Всего лишь 256 Мб.
Оффлайн and
  • 418
« Ответ #9 : Июля 18, 2008, 00:33:43 »
Я конечно не специалист, но вопрос у меня такой с каких пор МС на хр стала ставить ДХ-10? Насколько я знаю это сделано было специально чтоб покупали висту. И еще насколько я знаю существует "хакерская" версия дх 10 под хр. Но не факт что у вас она хорошая... Верните взад ДХ 9 имхо...
ЗЫ: Для проверки железа скачайте какой нить linux livecd запишите образ на болванку и при загрузке запустите memtest(точно есть у opensuse, должно быть и в других но других я не пользую поэтому не знаю)
« Ответ #10 : Июля 18, 2008, 00:58:11 »
Нормальное видео, этот ноут не для крайзиса.
Оффлайн azerty
  • 12
« Ответ #11 : Августа 22, 2008, 15:05:23 »
По-моему, не установлен родной видео драйвер, из-за этого нет данных о видеокарте и некорректно установлен DX.
