ArchiCAD 16 Hotfix 2 (Build 3270)
Исправлено
- 144420 CRASH: Deleting a dimensioned point of a polyline could crash ArchiCAD.
- 143903 DATA LOSS: Data of Roof elements could go Invalid with particular file.
- 144968 DOCUMENT: Symbolic and Cut Plane display of custom Curtain Wall panels was different.
- 144627 EDIT: While using the Bulge function the segmentation of the feedback and the resulting Morph was different.
- 143105 EDIT: 3D openings could only be placed to the left side of the first input click.
- 144515 EDIT: If a view is traced below another, hiding the layer of a selected
element and switching to Reference view made the cursor flash. - 144962 EDIT: In Curtain Wall Edit mode the Element ID Manager showed attributes
without showing the hierarchy of elements and sub elements. - 144254 EDIT: In special circumstances the look of Library objects were not regenerated after changing their parameters.
- 144085 EDIT: Mouse scrolling could change Renovation status back to existing if Trace reference was on
- 144284 EDIT: On floorplan using tracker's x-y coordinates for placing a Door or a
Window in a wall resulted in a bad position within the wall. - 143097 EDIT: On HiDPI displays 2D and 3D windows didn't exploit the higher resolution.
- 143069 EDIT: On HiDPI displays pop-up palette icons were wrong.
- 144794 EDIT: In MAC OS X 10.8 dotted lines were not visible.
- 107293 EDIT: In Windows if the DPI of the display was set to 125% then tooltips were unusable.
- 144641 EDIT: Turning off the Show Skin Separator Lines option made turning it on again difficult.
- 143466 EDIT: With particular files 3D preview could be missing when editing morphs.
- 142799 ENERGY EVALUATION: Changing the Mechanical Cooling type between Air Cooled and
Water Cooled values didn't affect the values of Auxiliary systems. - 142829 ENERGY EVALUATION: Ecodesigner could take another material than the one had selected in the material catalogue.
- 143032 ENERGY EVALUATION: Empty Windows/Doors did not appear as Uncovered Area.
- 142815 ENERGY EVALUATION: Glazing selection set wrong Opaque U value.
- 142880 ENERGY EVALUATION: Heat Pump for Cooling Source didn't have any effect on the result.
- 144094 ENERGY EVALUATION: Project Location and Climate data contained different
locations after "Start Energy Simulation" in the AUS ArchiCAD. - 143949 ENERGY EVALUATION: Some zones could be erroneously shown as outdated.
- 143931 ENERGY EVALUATION: The text explaining the CO2 emission graphics was erroneously positioned.
- 142737 ENERGY EVALUATION: Total area sorting didn't work on OpeningsTabPage.
- 142820 ENERGY EVALUATION: With migrated projects small infiltration could appear even though all shell elements were airtight.
- 144967 FILE/IFC: After exporting IFC file containing openings with casing from ArchiCAD
then importing the IFC file again into ArchiCAD the opening size could
become bigger. - 145188 FILE/IFC: Classification Reference values couldn't be chosen.
- 144637 FILE/IFC: Empty openings originated from migrated files got exported to IFC with erroneous geometry.
- 144093 FILE/IFC: GrossWallArea and NetWallArea were exported incorrectly into IFC.
- 143209 FILE/IFC: Exported IFC file geometry of slanted reveals was incorrect.
- 143035 FILE/IFC: Exported IFC files had the time stamp the wrong format.
- 135950 FILE/IFC: Particular Curtain Wall elements could go be missing missing in IFC exports.
- 127256 FILE/IFC: Older IFC translators could not be used after importing them in ArchiCAD 16
- 144955 FILE/IFC: Update with IFC command did not update Zone number and name with particular files.
- 142912 FILE/IFC: Wall holes were exported with erroneous geometry in certain circumstances.
- 144496 FILE/IFC: With particular project the exported value for IfcBuildingLocalplacement was wrong.
- 143151 LIBRARY/MODEL : GDL's script created from morphs could get wrong line
endings which made these object unusable on the BIMComponents site. - 143217 LIBRARY/MODEL: Object-Morph-Object round trip could produce macro errors.
- 144568 LIBRARY: Downloading two objects using the same macro from the BIMcomponents
site caused the macro to be placed twice in the embedded library. - 142444 MODEL: Changing the ID of a Curtain Wall component made the component disappear.
- 143104 MODEL: Holes in beams could not be deleted.
- 143103 MODEL: Holes in beams could not be elevated.
- 143764 MODEL: Hotlink Module could move to a different story after breaking a copy of the original one and resaving it.
- 143130 MODEL: In particular circumstances in the Project map some floors could get duplicated.
- 144077 MODEL: OpenGL shadows could get lost completely in case of particular files on Mac OS X 10.6.
- 144267 MODEL: Particular Composite structure got invalid skins after appending it through attribute manager.
- 144922 MODEL: For Mac OS X 10.8 antializing feature has been re-enabled on Mac
Graphics drivers that have been tested by Graphisoft. For more
information go here. - 145144 SPEED: Stretching a polyline could cause slowdown in case of particular files
- 130395 SPEED: To Room and From Room parameters of Zones were unnecessarily
recalculated after zooming or panning causing slow navigation with
certain files. - 142991 SPEED: With particular files hovering the cursor over the edge of a slab the
status of the cursor would change very slowly and the pet palette would
appear with delay. - 144771 TEAMWORK: Deprecated image warning could come up regularly, even though there were no deprecated images in the project.
- 133631 TEAMWORK/LIBRARY: After a library element was modified on the BIM Server its 3D look
would be refreshed in ArchiCAD only after refreshing the Library Manager
dialog or if the instance of the library element had been modified. - 144203 TEAMWORK/LIBRARY: If a library had been uploaded to a BIM Server from a mapped network
drive in a previous version of ArchiCAD then it could not be refreshed
in the current one. - 144761 WORK ENVIRONMENT: Quick Layers command was erroneously translated to German in the GER ArchiCAD version in the Work Environment.
Bugs fixed in optional Graphisoft components:
- 144572 BIMx: After exporting a particular file to BIMx the application closed at once.
- 145242 BIMx: Bimx could crash with particular project after activating the Info tool or turning on Outlines.
- 143452 BIMx: Improved image quality on HiDPI displays.
- 142425 BIMx: There was no possibility to accelerate the navigation along the z axis.
Download this Hotfixfor all languages except for RUS language version
only for RUS language version,The ArchiCAD 16 Hotfix 2 (3270) installer files for the Russian language version are available through the links below. These files
contain a fix, which makes the new "Limit navigation to gallery views"
feature of BIMx Desktop Viewer available in the Russian language version
as well.
